Overheating
Old Nov 21, 2024 | 10:34 AM
Originally Posted by rwfnetworking
Btw, my 212 degrees was just a estimate at the time. It went much higher. My temps are usually in the 190's. All these suggestions did remind me that two or three times I have seen my temperature gauge not reading anything. I thought maybe it was because of the cooler temps right now but it happened at least three times so maybe I just have a problem with the engine coolant temperature sensor?
What do you mean estimate ? You have a numeric digital coolant temp gauge in the DIC display on your car. No estimates needed.
If the analog gauge and digital gauge don’t show a temp, it’s usually caused by the coolant not heating up fast enough from startup. That usually points to a bad thermostat. Will trigger a P0128 code.
Very small chance it’s the temperature sending unit.
Old Nov 21, 2024 | 10:47 AM
rwfnetworking's Avatar
Originally Posted by jimvw
If your temp goes to - - - F then you have a problem. Mine was due to the thermostat sticking open. this also shuts down the A/C from working. caused by temp not getting warm fast enough for the computer's liking. I know it doesn't make sense and you'd think it would be a temp sensor, but it isn't. replace the thermostat with a AC Delco unit or it will happen again too soon.
Yes, I did have my display showing --- F for over 10-12 minutes of driving. F finally at my destination it started showing a temp. The analog gauge was also not moving and bottomed out.
Old Nov 21, 2024 | 10:50 AM
I mean It was getting hotter than just 212. At that point I shut the engine off. As I mentioned,, it's normally running in the 190's.
Old Nov 21, 2024 | 10:51 AM
Originally Posted by donbrew
I wonder if you are not mentioning the CEL?
No CEL light.
Old Nov 21, 2024 | 11:12 AM
My guess is a temp sensor and/or fan.
Old Nov 21, 2024 | 11:31 AM
Or air in the cooling system
Old Nov 21, 2024 | 12:23 PM
Thanks for all the suggestions.
Another symptom that I noticed today after it was idling for about 30 minutes the temperature went up to 217, the fan turned on and it still hasn't turned off after 45 minutes and the temperature has been holding at 168.
I haven't seen the dashes in the digital display today. Maybe just replace the temp sensor since it's easier to get at?
Old Nov 21, 2024 | 01:48 PM
While you’re at it change the thermostat, AC Delco 131-158 180 degrees, don’t install a cheaper aftermarket part, you’ll be doing the job twice! Just 2 ,10 mm bolts
Old Nov 21, 2024 | 08:45 PM
168F is too low. The fan should turn back off at about 179F. After warm up the temp should NEVER go below 179F.
2008LShhrHou
Jun 29, 2023 09:46 PM
Aj1968
Aug 30, 2022 04:57 PM
hardwaremack
Apr 4, 2017 01:08 PM
rwatkins
Maintenance and Upkeep
25
Aug 3, 2016 09:49 AM
antonalex
2.4L Performance Tech
10
Sep 24, 2009 01:31 PM
