Paint and Adhesive ... Don't sniff either y'all 😊
Old Mar 12, 2021 | 07:00 AM
Ronnie's Avatar
Thanks again y'all.
Any recommendations for affixing rubber tread to back bumper?
Old Mar 12, 2021 | 09:00 AM
3M molding tape , see in here
https://www.chevyhhr.net/forums/gene...dscreen-64158/
Old Mar 12, 2021 | 11:40 AM
For nearly permanent use any exterior rated contact cement. You coat both surfaces, let them set a few minutes then slap together with some pressure. done.
Old Mar 12, 2021 | 01:02 PM
Originally Posted by Ronnie
Thanks again y'all.
Factory did it with 3M molding tape. I installed mine new out of the package, tape already applied.
Old Mar 12, 2021 | 10:50 PM
Ronnie's Avatar
I haven't had good luck with 3M...contact cement may be the best solution.
Old Mar 13, 2021 | 07:03 AM
With either product , you have to clean the surface of wax and polish.
Old Mar 13, 2021 | 07:11 AM
2manyvans's Avatar
Most of the trim I have installed that has the 3-M tape comes with an adhesion promotor
Old Mar 13, 2021 | 07:43 AM
Clean and smooth surface prep is the key when using 3M adhesive tapes. Used their products on lots of things with excellent results.
The bug deflector on my Dodge truck was firmly attached with 3M tape for 22 years ! The deflector finally got UV brittle and cracked. The 3M tape was still holding strong and a real beeoch to remove.
Old Mar 13, 2021 | 10:11 AM
Radco's Avatar
I put on the rear rubber bumper pad had 3M Tape on it 9+ years ago .on my HHR and my son's. As mentioned prep is the key.
Old Mar 13, 2021 | 10:33 AM
I’d have to check with fastsuv, to confirm Oldblue still has the rear bumper protector, I installed that in May 2010, it was still on there when he picked the HHR up in September 2019
This was taken the day he picked it up.
