For nearly permanent use any exterior rated contact cement. You coat both surfaces, let them set a few minutes then slap together with some pressure. done.
Clean and smooth surface prep is the key when using 3M adhesive tapes. Used their products on lots of things with excellent results.
The bug deflector on my Dodge truck was firmly attached with 3M tape for 22 years ! The deflector finally got UV brittle and cracked. The 3M tape was still holding strong and a real beeoch to remove.
I’d have to check with fastsuv, to confirm Oldblue still has the rear bumper protector, I installed that in May 2010, it was still on there when he picked the HHR up in September 2019
