Panel rear doors
Old Aug 27, 2012 | 07:14 PM
speedwagen's Avatar
I have the same problem on the drivers side rear door.
I put a shim washer on the B pillar, but it was not any help,so I guess I need to pull of the door panel and shim the two bolts on the door https://www.chevyhhr.net/forums/show...p?p=345279#186
Old Sep 5, 2012 | 10:17 AM
songman1505's Avatar
Originally Posted by VinceP
This is common apparently. Mine would do the same thing. I could hear the actuator but no open door for a few pushes of the button. I found that if I keep the seals lubricated with dielectric grease it is no longer a problem. The seals get sticky here in Texas from the heat and the grease prevents this from happening. The dielectric grease also keeps the seals from drying out.
Thanks I'll try that. I am in new mexico and bought the truck from arizona so that could be a possibility here too.
Old Sep 10, 2012 | 11:29 AM
Mikeco613's Avatar
I just put the shims in and it works perfectly.
Old Sep 10, 2012 | 12:52 PM
Panels4Life's Avatar
Special buttons?
I cant open doors with my key fob. What year is your Panel?
Old Sep 10, 2012 | 06:01 PM
Mikeco613's Avatar
Mines a 08
Old Sep 10, 2012 | 11:50 PM
Thats cause yours is an 07..
Key fob door poppers started for the '08 model year & later..
Mine is an '08 Panel
HUNTMASTER
Mar 15, 2014 12:14 AM
keg_head
Sep 15, 2008 05:43 AM
