radio probelms
radio probelms
i would like to know if i can fix this problem or i have to take it in
here is the problem my radio just quit the volume show it turning up the tuner turns station but no other buttons work no sounds nothing and on my display is all frequencies it shows am fm and xm stations does anyone know if i can fix this myself or take it in
Not TRYING to be a jerk......but can you use some punctuation? It may make it easier to understand what your asking.
But generally, if part of a radio is working and the other isn't....take it to the dealer...especially if its under warranty.
Check the automatic sound levels. It has 3 settings you can chose so that the radio goes up or down as your speed does. If you use the high setting, sometimes when you slow down, you can't hear the radio. It's still on but this automatic control turns it way to low. Also, if you turn it down while you're travelling fast, you can turn it too low to hear. I learned the hard way!
Pull the owner's manual out and learn how to adjust this feature to match your type of driving.
Sno White
"How To" Tutorial Library
11
Aug 26, 2009 05:48 PM
to the site!!!
