Rain leak Passenger side under glove box
Old Mar 26, 2019 | 08:01 PM
Radco's Avatar
Interesting ! So far I have been lucky :) Hope it stays that way lol
Old Mar 27, 2019 | 08:42 AM
solman98's Avatar
It was an issue with 06 models, maybe some early 07's.
Old Mar 27, 2019 | 12:34 PM
Cat Man HHR's Avatar
Please read post #3
Old Mar 27, 2019 | 02:19 PM
I checked veedub has a 2007
Old Mar 28, 2019 | 09:06 AM
solman98's Avatar
Originally Posted by Cat Man HHR
Please read post #3
Your point?
Old May 6, 2019 | 10:44 AM
SteddyTeddy's Avatar
So I pulled the cowl off my wife's 2008 which we purchased new. The stick on cover that fails was never installed from the factory!!!!
Old May 6, 2019 | 11:59 AM
This was a 2006 model year problem. 2008 doesn't need it
Old Oct 8, 2019 | 01:05 PM
veedub's Avatar
Originally Posted by donbrew
I don't even have to look at your profile to know you have a 2006 or early 2007. Soon your fan resistor and/or motor will malfunction (only runs on high or not at all).
Yes, that happened previously and i had the motor replaced in July. It leaked only once after that but since then it hasn't. I do hear water sloshing around when i step on the gas after being stopped. I am guessing that is coming from the radiator?
Old Oct 9, 2019 | 01:11 PM
J W Davis's Avatar
Sounds like from your discription that the condensate water from the A/C is not draining. Many good threads on this subject, easy fix.
Old Oct 9, 2019 | 01:17 PM
If the sloshing is coming from behind the radio it means you are low on coolant.
The AC condensate pan is under/behind the radio and usually leaks to the passenger side if the drain out the firewall is clogged.
