Rain leak Passenger side under glove box
Old Nov 3, 2019 | 11:48 AM
Lizmic55's Avatar
Recent 06 owner concerning cabin water leakage
Originally Posted by donbrew
If the sloshing is coming from behind the radio it means you are low on coolant.
The AC condensate pan is under/behind the radio and usually leaks to the passenger side if the drain out the firewall is clogged.
So not sure if posting correctly, but as recent 06 owner it seems water is leaking in from 2 sources: the cowl under wipers that needs a butyl patch & after heavy AC usage. I def 1st noticed in late summer, but all seems fine now as live in MN & no more using AC or any rain as it's been below freezing last 2-3 weeks. Also concerned if this has caused excessive rusting due to previous owners never fixing it?
Old Nov 3, 2019 | 12:20 PM
The AC runs in defrost.
Old Nov 3, 2019 | 12:46 PM
It may not be raining, but snow melts so you can have the same issue in the winter. The leaking butyl patch NEEDS to be fixed asap to prevent damage to the fans resistor as well as the carpet, floorpan etc. etc...
Re: rusting? too many variables to say yes or no. You have to take the cowl off and eyeball it from on top, as well as from the bottom.
Old Nov 3, 2019 | 07:54 PM
Lonwane's Avatar
I might add that below that patch is a drain that can get clogged. I know this because mine did as that area was filled with 13 years of mesquite leaves.
Just look in my photos
It doesn't take much to remove the cowl repair the patch and clear the drain
Old Feb 5, 2020 | 06:56 PM
veedub's Avatar
I finally had time to investigate the source of my rain leak today. It's now all cleaned out. I'm just waiting on the butyl patch to arrive from the dealer so i can put it on tomorrow.
Old May 22, 2020 | 10:31 AM
  #26
And here’s a video with the new GM replacement patch install
kladaniels
Mar 17, 2014 12:32 PM
CruzHHR
Sep 29, 2013 09:27 AM
SteveMaine
May 25, 2013 10:46 AM
ELPasoHHR
Nov 15, 2011 03:16 PM
pyro panel
Oct 12, 2011 04:53 PM
