reattaching door dust shields.
Old Feb 15, 2018 | 04:23 PM
scoutmstr's Avatar
A search turned up nothing to the question. From the factory there is a yellow non-hardening sticky type glue that holds the dust shield to the interior of the door skin between the door skin on the inside and the trim panel. I know there are many other solutions to reattach the dust shield (thin foam sheet) to the door suchas butyl tape etc but does anyone know what GM used and where to get it? Dealers are no help
Old Feb 15, 2018 | 04:29 PM
GM used a butyl sealant, similar to weather striping sealant.
PRO FORM - Products
I’ve nver looked into getting any anywhere , thinking they must purchase it in huge bulk amounts.
Old Feb 15, 2018 | 06:18 PM
The stuff they used on my Mazda melts in the sun and drips on the ground. Yuck!
GM actually calls it a "water deflector" and has no instructions as to a sealant. The instructions for replacement is this picture.
Old Feb 15, 2018 | 08:05 PM
gchapell's Avatar
Are you the referring to the bottom inside edge of the doors? Mine (2009 2lt) has nothing on the door but has a corresponding body mount gasket which follows the entire door opening. I've wondered about this.
Thanks.
Old Feb 16, 2018 | 07:35 AM
No, that’s a splash shield gasket.
jeff schaffer
Mods - Exterior
13
May 4, 2014 01:29 AM
jaymz
Aug 10, 2011 06:09 PM
rockNroad
Apr 12, 2007 02:36 PM
cjuetten
Jun 12, 2006 06:37 PM
SIHHR
Feb 20, 2006 01:16 PM
