Reduced Power warning and blower fan
Old Mar 9, 2021 | 06:59 AM
Finn1122's Avatar
My 2004 Chevy Colorado with 18,000 miles has 2 issues. The blower fan works but maybe not on all speeds sporadically. You go over a bump and the fan will cut out . Then next thing you know it is working on all speeds.
the second issue is I get a reduced power warning and then the truck shuts off. It will let you coast but no power what so ever. Any ideas what this could be? I did have someone look at it and said something like computer module something but he isn’t interested in doing the job
Last edited by Finn1122; Mar 9, 2021 at 07:02 AM. Reason: Forgot information and a few missed words
Old Mar 9, 2021 | 07:22 AM
Welcome, now this site is about and for the 2006 to 2011 Chevrolet HHR model years, but sounds like your truck maybe having an issue with loose wires, fuse , relays, fan or a faulty HVAC control module. Something you’re gonna need to investigate! Lift your hood look at the fuses and relays. I don’t know if the Colorado has a fuse box under the dash , so have a look under there too.
Old Mar 9, 2021 | 07:24 AM
Lonwane's Avatar
Het Finn,
This site is for HHR's.
As much as I would like to help, I one thing about a Colorado.
It,s a Chevy.
Try a Colorado site.
Old Mar 9, 2021 | 08:24 AM
HHR and the Colorado share nothing in common except they are both Chevrolets. Everything else is different between the 2.
(the 2004 Colorado is an Isuzu designed truck for GM)
You would likely find some help from a Colorado forum.
woodman17
Nov 21, 2013 10:35 AM
Stevethefolkie
Aug 7, 2013 04:32 PM
mn64falcon
Apr 13, 2012 09:19 AM
RLash
Sep 28, 2010 11:26 AM
budokai140
Feb 10, 2009 12:04 PM
