Remote Start distance ?
Old Jan 14, 2012 | 09:58 AM
Laco's Avatar
I don't have remote start on my 2007, as its a five speed, but I would not want to use it, unless the car was in sight. Just my error on the side of caution SOP, I guess.
Old Jan 14, 2012 | 10:31 AM
db/sb's Avatar
The car is still locked even after you use the remote start until you unlock it.
Old Dec 10, 2012 | 07:36 PM
Ogre Ralf's Avatar
Does anyone know where the receiver is located in the car? My range goes from 150 ft to 0 ft intermittenly - have replaced battery in remote with brand new one but got no consistent performance. Don't understand why this started now after 6 years - don't even have 50 K on it yet.
Old Dec 11, 2012 | 01:18 AM
rihan's Avatar
I bet you $100 its the remote. The remotes have a habit of the battery terminal inside breaking loose from its soldering. Take it apart and I bet you will find it has popped apart from the circuit board. Its an easy fix if you are good at soldering, otherwise a new remote is in order.
Old Dec 11, 2012 | 05:18 AM
geg's Avatar
geg
I could be wrong - but it's on the ceiling, in the rear view mirror.
Old Dec 11, 2012 | 07:56 AM
rywegh's Avatar
Not always true... just because the person might not be good at soldering that they have to buy a new one. They could take it to a computer/electronics repair shop for that.
at 300 for the new screen remote and flashing I would seriously consider taking car to stereo shop and have an aftermarket security remote start system installed.
Old Dec 11, 2012 | 01:47 PM
db/sb's Avatar
Not sure what you mean by 'new screen remote and flashing' but the remotes are 35-50 bucks depending on where you get them and the programming is around 25-40 and even free is you know someone at the dealership (as do I). So the cost is nowhere near the 300 you mention. No need to over think something so simple especially with the problems I've seen people have with aftermarket systems and the clowns I see at the shops that install them.
Old Dec 11, 2012 | 01:58 PM
wmsburghhr's Avatar
Think he is referring to this remote. see post 4 of this thd https://www.chevyhhr.net/forums/show...ghlight=remote
http://www.gmpartszone.com/scripts/p...product=299780
Old Dec 11, 2012 | 05:12 PM
db/sb's Avatar
I know. That remote was briefly mentioned earlier in this thread also but it isn't what was being discussed when this old thread was revived after post 12 by Ogre Ralf. His question had nothing to do with two way remotes or aftermarket stereo shop systems.
Old Dec 11, 2012 | 05:32 PM
Yeah. Happens alot here. A thread will stray away from the original post and you'll get some later posts that revert back to the start of the thread.
