Replace 4 parts together-would my HHR start
Old Jun 1, 2022 | 11:46 AM
greg8453's Avatar
You need a good scan tool and a pass thru devise to do this work.I'm not sure the cks will learn on it's own.
Old Jun 1, 2022 | 05:55 PM
RR72922's Avatar
I have fallowed a senior retired local mechanic and ordered a New VXDIAG VCX NANO GDS2 OBD2 Scanner Diagnostic Tool Fit for GM/Opel and will not do anything until I get it and have to learn how to use it.
If this one doesn't work good enough I will purchase a better one.
Old Jun 1, 2022 | 07:18 PM
No the CPS will not relearn on its own
Old Jun 1, 2022 | 07:47 PM
The CKS does not relearn itself. It might not throw a code but that does not mean the variation is learned. The code it might throw is for "no data" not incorrect data.
The 2006 ignition system is not the same as the 2007 system, so the ECM is different, and the harness is different
Old Jun 1, 2022 | 09:40 PM
RR72922's Avatar
The second one that I found to purchase all these parts from is a 2007 HHR LS the same as mine, still starts and drivable just terrible rear dent.
They are Both 2007 HHR LS 2.2 LTR, so will the ECM and Harness be the same and could the CPS relearn on it's own?
Old Jun 1, 2022 | 09:46 PM
What's wrong with your ECM and BCM? It's extremely rare that these computers go bad.
Old Jun 2, 2022 | 06:43 AM
Again no the CPS doesn’t learn by itself.
Old Jun 2, 2022 | 04:01 PM
You would have an illegal car no matter what.
Thread closed
LadyBee
Jul 10, 2022 01:15 PM
uluz2a6
Jan 3, 2021 08:13 PM
brittlm
Aug 24, 2020 09:19 PM
JMAM
Jul 5, 2018 02:35 PM
swali
Oct 18, 2014 03:05 PM
