Replacing oil pressure switch but concerned about starter...
Old Mar 4, 2024 | 05:23 PM
Atop3429's Avatar
I'm putting this beautiful southern pre-Spring day to good use! (working on my beloved orange HHR)
I noticed my HHR's oil pressure switch is leaking badly, so of course oil and dirt has made quite a mess of the general area. The switch replacement is easy, and parts are on the way. But my concern is for the starter which is directly under it and is dripping oil. So far, I've had no issues. Is there a way to clean the starter when I take it off to more easily access the switch? Or, should I just go ahead and replace the starter? (I'm between jobs at the moment so would rather NOT spend money if I can avoid it, but I do have it if the general consensus is I should replace it or else.)
Thanks!
Old Mar 5, 2024 | 07:13 AM
You could just give the starter a spritz of brake parts cleaner or GPC . Just wipe the drips off with a paper towel or a rag.
Old Mar 5, 2024 | 07:57 AM
Lonwane's Avatar
I agree with Oldblue..
BrakeKleen and a rag.
Old Mar 5, 2024 | 08:34 AM
Atop3429's Avatar
Thank you, very much appreciated!
Old Mar 5, 2024 | 08:55 AM
fastsuv's Avatar
One warning:
Keep brake cleaner away from plastic parts of the starter. It will soften many plastics.
Hold the starter so the metal part is facing down and the end with the wire connections (which has the plastics) facing up. Spray the sides and bottom end of the starter without spraying the plastic end. That way the cleaner runs down the starter and off the end without soaking the plastic parts.
Steve
Old Mar 5, 2024 | 09:12 AM
greg8453's Avatar
Don't spray it with anything. Drive it.
Old Mar 5, 2024 | 10:34 AM
I would use your favorite color spray cleaner, purple, orange, etc. Leave it on the engine rinse with the garden hose. Same way I would clean the entire engine compartment.
If they were worried about water they would put the radiator somewhere else and seal the compartment.
Rickpell
Aug 10, 2019 06:33 AM
tempestram
"How To" Tutorial Library
Dec 30, 2014 08:51 AM
gschroed
Jan 29, 2014 07:24 AM
Carnage SS09
Jan 5, 2014 05:28 PM
Karmike2
Apr 14, 2008 07:12 PM
