Reset the oil life indicator..The easy way
Old Feb 21, 2009 | 11:32 PM
Snoopy's Avatar
Originally Posted by chevyorange
Resetting the oil life monitor is the same as resetting the trip milage. When you get toggle past the trip odo's and get to oil life, just hold the arrow button to reset. Simple!
So they changed it from the 2 button method in the 06-07???
Old Feb 21, 2009 | 11:34 PM
chevyorange's Avatar
In my 08, the INFO button toggles between Odo and Outside Temp>Trip A>Trip B>Coolant>Front Tire Pressure>Rear Tire Pressure>Oil Life>Avg MPH
Not in that order, its late.. but just hitting info toggles through these. Press the Arrow or Enter button to reset any of them that are resettable.
So, there are two buttons, if that is what you're talking about?
Old Feb 22, 2009 | 07:16 AM
From post 13 of this thread........
The 2 button method........ with engine off and key set at accessory......
Originally Posted by camaro98z28
Press the INFO Button on the steering wheel when it gets to the Oil Life %. Hold that button and the Arrow Button at the same time. Release and it will say "Oil Life Reset". Press arrow button again and it will then say something like "Confirm" Wut Ever. Press Arrow again and it will then go to 100%
Old Feb 23, 2009 | 07:31 AM
-md- HHR's Avatar
Originally Posted by RUDEINC
I stumbled across this weekend while I was programming my nitrous control unit. The easy way to reset the DIC oil life monitor. It's just like other GM vehicles that use the oil reset feature. Some of you may already be familliar with this. Here are the steps...
1......Key on ,not running
2......Step on the gas pedal to the floor 3x in 5 seconds or less.
3......Oil life indicator will go back to 100%
This works out great for me, because I can never remember how to do it using the steering wheel controls. I always end up looking in the owners manual...lol...Just thought I would share....Regards
Same as most GM's.
Old Feb 23, 2009 | 01:31 PM
masterchief1112's Avatar
hmm i cant just hold the arrow on mine i have to go into the menu thingy
Old Feb 23, 2009 | 02:19 PM
  #26
ZTony8's Avatar
The 08 cars are different.
Old Feb 23, 2009 | 05:25 PM
  #27
Snoopy's Avatar
Thanks Tony....thats the point I was trying to get answered !!
Old Feb 25, 2009 | 08:11 AM
  #28
ChevyMgr's Avatar
From the Official Recall and TSB Thread
#PIP4511: Unable To Reset The Engine Oil Life System Using The Accelerator Pedal - keywords DIC ECM EOL engine inop inoperative intermittent life lof lnf maintenance message monitor oil OLM pedal performance - (Oct 16, 2008)
Subject: Unable to Reset the Engine Oil Life System Using the Accelerator Pedal
Models: 2008-2009 Chevrolet HHR SS With Engine RPO LNF ONLY
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
A technician may report that the Engine Oil Life (EOL) will not reset.
Recommendation/Instructions:
Engineering has determined that the ECM for the 2008-09 HHR SS does not support the use of the accelerator pedal for the Engine Oil Life System reset procedure. This is listed incorrectly in eSI and the Owners Manuals of this vehicle; and is in the process of being changed.
Technicians should be advised to use the DIC procedure or Tech2 to perform the EOL reset.
Old Feb 25, 2009 | 11:49 AM
  #29
Silver bullet's Avatar
Maybe there's something I'm missing, but couldn't pumping the accelerator pedal in this manner flood the engine?
Old Feb 25, 2009 | 12:43 PM
  #30
The car is drive by wire and fuel injected so no fuel is moving into the unless it is running. That woul happen on a old carb engine
