rev limeter
Old Aug 9, 2007 | 01:54 PM
gren25's Avatar
Question rev limeter
do the hhr's with a 2.4 have rev limiter's or governer's. I have a 2007 lt with a 2.4 and I was just playing around the other day revving the engine just listening to the sound, and it would't rev over 4000 rpm's is this how it's supposed to be. does anyone know. thanks btw this is my first post.
Old Aug 9, 2007 | 01:56 PM
courthousedeb's Avatar
Yep...they've got a rev limiter/govener hooked up. Guess it's to keep us from going too nuts and blowing up our HHR's. I've hit mine several times screwing around.
Old Aug 9, 2007 | 02:00 PM
gren25's Avatar
thanks for the reply, that's good to know.
Old Aug 9, 2007 | 02:19 PM
Don't know about a rev limiter, but it does have a speed gov. Will only let you get to 110, however, if you go into "I" drive, it bypasses the gov. Hard on the economy, but you can achieve higher speeds.
Old Aug 9, 2007 | 02:55 PM
JoeR's Avatar
On the 2.4's w/ auto, normal rev limiter is set to 6,750 in gear and 4,000 in P/N. It's done via fuel cutoff and the electronic thottle.
Speed is governed at 108.
Both can be "fixed".
Not sure about the 2.2 much. I think rev limiter is set to 6,500 and likely has a similar setting for lower P/N.
BYW, WELCOME!!!
The HHR has both.
Old Aug 9, 2007 | 03:09 PM
JimZ_HHR's Avatar
BYW, WELCOME!!!
108 Was the fastest I could get mine.....
Old Aug 9, 2007 | 04:27 PM
Originally Posted by gren25
I have a 2007 lt with a 2.4 btw this is my first post.
Size:  5.6 KB to the site!!!
Old Aug 9, 2007 | 05:35 PM
gren25's Avatar
thanks for the welcome
Old Aug 9, 2007 | 05:42 PM
JESSE's Avatar
BYW, WELCOME!!!
Mine was Hp Tuned, I have done just a bit over 108, Just a bit! WelcomeGren25!
