Safety belt on obd
Old 12-25-2018, 10:29 PM
Josh Roth's Avatar
Safety belt on obd
I recently had to take my 10 hhr on cause the cruise had stopped working, Well they replaced the brake module but ever since then my seat belt light is always on and has never been on before. I bought this vehicle used from new Mexico and well the seat belt wires had been clipped only for driver and no light well when I put in the led lights the brake module went I didn't know led don't use a ground but i'm not posting about that I just want a clear obd instrument panel again please any help on figuring this out would be greatly appreciated!
Josh Roth is offline
Old 12-26-2018, 01:00 AM
Sorry - I don't have the patience to try and decipher what you are trying to say. Punctuation and sentences would really help clarify the situation.
whopper is offline
Old 12-26-2018, 01:14 AM
Josh Roth's Avatar
Seatbelt on obd?
[QUOTE=Josh Roth;857857]I recently had to take my 10 hhr in cause the cruise had stopped working well they replaced the brake module but ever since then my seat belt light is always on and has never been on before I bought this vehicle used from new Mexico and well the seat belt had been off it was previously clipped only for driver and no light well when I put in the led lights the brake module went I didn't know led don't have a ground but i'm not posting about that I just want a clear obd instrument panel again please any help on figuring this out would be greatly appreciated!!!!OTE]
Old 12-26-2018, 01:22 AM
That really doesn't help much - sorry.
whopper is offline
Old 12-26-2018, 01:31 AM
Josh Roth's Avatar
Sorry
Can't draw you a picture of the cluster with the seatbelt light on!!
Old 12-26-2018, 01:45 AM
A picture is not necessary - but, can you at least make sentences out of what you wrote? I'm not about to decipher what it is you are trying to say.
whopper is offline
Old 12-26-2018, 02:49 AM
Cat Man HHR's Avatar
I somehow get the impression the seat belt light is always on.
I too can't really understand his explanation of the problem.
Cat Man HHR is offline
Old 12-26-2018, 04:55 AM
I recently had to take my 10 hhr on cause the cruise had stopped working .
Well they replaced the brake module but ever since then my seat belt light is always on and is never been on before .
I bought this vehicle used from new Mexico and will the seat belt woes had been clipped only for driver and no light will when I put in the led lights the brake module went .
I didn't know led don't have a ground but i'm not paying about that.
I just want a clear obd instrument panel again.
Please any help on figuring this out would be greatly appreciated!
Tried to clean this up. Highlighted the parts that need translation.
firemangeorge is offline
Old 12-26-2018, 08:07 AM
You could try disconnecting the ground wire on the battery for a few minutes. If there are no faults the light will stay off.
I suspect the relevant sentence "had been clipped only for driver". That might be what is going on. Does it mean that the previous owner cut the wires for the seat sensors and after they were repaired the light came on?
The cruise control now works after you replaced the bulbs in the high mounted brake light? Don't know what grounding LEDs is about. They do need a ground.
donbrew is offline
Old 12-26-2018, 12:01 PM
Cruise will not function if there is a CEL ,
LED’s in the high brake light , can cause this problem, it has to do with resistance, not about grounds.
Oldblue is offline
Quick Reply: Safety belt on obd
