Shift handle.
I just saw Slide Rights shifter mod and it seems easy to me now. A simple sleeve I can use the setscrew to index in a slot and have a plunger and push down on the handle to activate the reverse lockout. I might still decide to do a pivot with the double ring for the lockout.
Now that the voices in my head have thought about it I've figured out how to do it. I'll make a sleeve tube and attach the double ring solidly to it. Then attach the handle to a bolt/plunger that fits inside the tube with a setscrew and slot with an extra spring. When I need to shift I can squeeze the handle down to engage the interlock. It will look like a Hurst race shifter. Once I get done with the body and suspension I'm on this like a bad smell!!!
A sleeve tube secured to the stock tube with the finger rings secured to it and a bolt screwed into the handle turned down on the end to act as a plunger for the bypass. Have a spring to push against and a slot and setscrew to index the handle. You would push the handle down for the shifter bypass or squeeze the handle using the rings.
