Shift handle.
Old Apr 16, 2022 | 04:42 PM
jimvw's Avatar
I wish they had the readout for what gear they are in on the dask. Hard to see at night and I don't always remember to count.
Old Apr 17, 2022 | 10:12 PM
Hvymax's Avatar
I just saw Slide Rights shifter mod and it seems easy to me now. A simple sleeve I can use the setscrew to index in a slot and have a plunger and push down on the handle to activate the reverse lockout. I might still decide to do a pivot with the double ring for the lockout.
Old Apr 18, 2022 | 06:45 AM
I followed slide’s idea for the shifter, I used a bolt to push down to release the shift select lock.
Old Apr 18, 2022 | 10:48 AM
Hvymax's Avatar
I must say that would be a good anti theft measure. Push down on the shifter to go.
Old Apr 24, 2022 | 07:40 PM
Hvymax's Avatar
Now that the voices in my head have thought about it I've figured out how to do it. I'll make a sleeve tube and attach the double ring solidly to it. Then attach the handle to a bolt/plunger that fits inside the tube with a setscrew and slot with an extra spring. When I need to shift I can squeeze the handle down to engage the interlock. It will look like a Hurst race shifter. Once I get done with the body and suspension I'm on this like a bad smell!!!
Old Apr 25, 2022 | 07:47 PM
Hvymax's Avatar
I got the Pleather skirt down but don't see how to remove the handle. The older ones had a setscrew on the back.
Old Apr 29, 2022 | 07:41 PM
Hvymax's Avatar
I found this and decided to give it a try. If I don't like it I can always get on fabbing the Hurst.
Old Apr 29, 2022 | 07:53 PM
Oh wow, that certainly goes with your theme!
Old May 7, 2022 | 01:59 PM
califphil's Avatar
I would love to have a Hurst shift handle on my automatic shifter.
Old May 7, 2022 | 03:13 PM
Hvymax's Avatar
A sleeve tube secured to the stock tube with the finger rings secured to it and a bolt screwed into the handle turned down on the end to act as a plunger for the bypass. Have a spring to push against and a slot and setscrew to index the handle. You would push the handle down for the shifter bypass or squeeze the handle using the rings.
