Slight Wobble after hitting small bumps or potholes.
Old Oct 5, 2023 | 12:14 PM
Beejmamdude's Avatar
I guess you missed this part of pulp's suggestion. Those are stamped steel. HHRs have aluminum.
This is the aluminum LCA im guessing?
Would it be ok and possible to just swap the bushings? Because all the bushings i could find were the same price as the whole cheap LCA off amazon.
They are actually very pretty once they're cleaned up a bit
Whats the meaning of hese letters. This LCA was the original i had just recently taken off. And the other shiny one came from a tow yard
Old Oct 5, 2023 | 12:54 PM
PulpFriction's Avatar
It is my understanding that the bushing will interchange, but have different surface treatments, and that the onse intentend for the steel arms will quickly corrode and seize into the aluminum arms. On the other hand, I see two other three different o.d.'s listed, but that could be typical misinfo. Do yours seem to be the same diameter?
If you do swap, try to seal things up to reduce galvanic corrosion.
You could try returning the steel ones, as they sold you the wrong parts. Their bushing might not last long, anyway. There's rubber and there's rubber.
There are some pretty inexpensive bushing out there that should be as least as good as the ones in the steels arms.
Don't know what the markings mean. SMW is the maker's mark, I surmise.
Rock auto has a ridiculous selection of these bushings, a couple on closeout, as cheap as $2.09/ea.
Old Oct 5, 2023 | 01:08 PM
Rear bushings are cheap, however you get what you pay for
https://www.rockauto.com/en/catalog/...m+bushing,7532
lunchbox
11
Nov 24, 2016 03:04 PM
CAS_PL
Jul 31, 2013 07:03 AM
2007blackk
7
Mar 29, 2012 11:07 AM
87silver
North East
Jun 5, 2011 06:23 PM
pyro panel
Jul 14, 2010 05:41 AM
