Snow problems
Old Dec 8, 2005 | 09:02 AM
snksknr94's Avatar
Then its probaly like my Sunfire was. There was no way to disable traction control.
Put it into first gear, that turns the traction control off in the j-bodies, maybe the same in the HHR.
Old Dec 8, 2005 | 09:05 AM
DANNOV's Avatar
Junior Member
Originally Posted by adamlowery
I read the manual and I saw nothing about how to turn it off.
I was afraid of that. I also have a VW Passat with traction control that cannot be turned off. What I to do to get rolling in a slippery situation from a standing stop in the VW, is to be very, very gentle with the accelerator, perhaps also even putting the trans into a higher gear to get a bit more traction with less wheel slip.
With front wheel drive cars (lots of weight on driving wheels) and reasonably good all-season tires you should be able to get moving with gentle accelerator action and a higher gear. Once you get moving your problem is solved. Trying to power out will not work because the traction control works against you, and not for you in that situation.
Old Dec 8, 2005 | 09:15 AM
adamlowery's Avatar
Well when I put it in the lowest gear, my traction control light came on. It's normally not on, unlesss its in the lowest gear.
Old Dec 8, 2005 | 11:30 AM
snksknr94's Avatar
Thats how you turn it off, put it in 1st.
Old Dec 8, 2005 | 11:38 AM
captain howdy's Avatar
That sucks! I want to turn it off on dry ground and I cant drive around in 1st all the time. Chevy should have put in a button or switch to turn it off.
Dharkons
Nov 29, 2017 04:42 AM
Jeff®
Nov 22, 2009 08:49 PM
87silver
Oct 24, 2009 09:14 PM
g&santiques
Jan 5, 2009 11:56 PM
SPPD
Jul 16, 2008 01:22 PM
