Snow problems
Then its probaly like my Sunfire was. There was no way to disable traction control.
Put it into first gear, that turns the traction control off in the j-bodies, maybe the same in the HHR.
Originally Posted by adamlowery
I read the manual and I saw nothing about how to turn it off.
With front wheel drive cars (lots of weight on driving wheels) and reasonably good all-season tires you should be able to get moving with gentle accelerator action and a higher gear. Once you get moving your problem is solved. Trying to power out will not work because the traction control works against you, and not for you in that situation.
Dharkons
Nov 29, 2017 04:42 AM
