Spare Tire Hold-down (wing nut)
Old Apr 29, 2015 | 07:25 PM
DoctorZ's Avatar
Wrong size spare. That makes sense why it won't fit together correctly.
That styrofoam tray obviously came from another type car since the HHR's did not come with them.
Yes it is interesting about the styrofoam tray since the jack and lug wrench are the correct ones.
Old Apr 29, 2015 | 07:41 PM
DoctorZ's Avatar
Originally Posted by donbrew
You should probably check the bolt pattern on the spare, before you need one.
Good idea. I thought about that. I measured the diameter of the bolt circle and it appears to be 110mm, but it is hard to get an exact measurement across the diameter with an odd number of bolt holes. Since there are wheels in 108, 112 and 115 as a possibility, I will have to test fit it on the studs to make sure.
But the best option is just to get the correct 15" spare wheel and tire so everything fits properly in the spare tire well...
Old Apr 29, 2015 | 08:21 PM
The 15" spare tires that came with the SS will not fit on the front of the car. (it's in the owners manual if you want the details ). That may be the reason the previous owner had a 16" spare in there.
Old Apr 30, 2015 | 05:00 PM
I wonder if the tray came with the models that had Slime pumps instead of spares?
Old May 5, 2015 | 10:41 AM
Winner, winner, chicken dinner! Give the man a prize!
You got it Don, the Styrofoam tray is/was part of the "Deluxe"(sarcasm intended)Can 'O Gloop and tire pump setup.
Ni keHerc
Sep 20, 2012 03:55 PM
270weatherby
Tires & Wheels
33
Oct 26, 2011 11:14 AM
HHR_style
Jun 1, 2009 01:47 PM
INSANE SS
Jan 13, 2009 07:23 PM
