speedometer?? cant get answer
Old Sep 22, 2009 | 08:09 PM
cathrob's Avatar
Question speedometer?? cant get answer
If I purchase a custom dash cluster will the install reflect my mileage or the replacement mileage and will it have to be programmed by the dealer .I have read many postings on the subject some say yes some say no .someone must have done this !!!please tell me your results thank you Rob
Old Sep 22, 2009 | 08:52 PM
Snoopy's Avatar
I would think it depends on the replacement.
If it replaces the ENTIRE cluster, i.e., you are removing all of the "receiving" units and other paraphernalia, then yes it will not display true mileage. I am not speaking for a supplier/maker who may have provided for this type of application. I've heard that some aftermarket manufacturers have provided for this by allowing the OEM odom. to maintain the original position, in some replacements
If you are placing the overlay, then probably not.
Don't forget, if replacing the entire unit, the DIC functions may be inoperable, as well.
Old Sep 22, 2009 | 09:14 PM
XXL's Avatar
XXL
Yes. No.
Check with DLVRNIT. He's in the middle of such a swap. In his case, the donor car was an SS and the receiver is not... so he is having some issues with the IP reading miles.
Old Sep 22, 2009 | 10:07 PM
AJochum's Avatar
Maybe - Maybe not.
Old Sep 22, 2009 | 10:16 PM
I was told when the SS first came out that it could not be programmed to work in a LT or LS.
Old Sep 24, 2009 | 05:59 PM
Dan's HHR's Avatar
Originally Posted by AJochum
Maybe - Maybe not.
Old Sep 24, 2009 | 08:45 PM
DLVRNIT's Avatar
Well I didn't want to Hassle with my dealership as all they seem to know is R & R (remove the bad part and re-install a new part) ! For your problem I have two recommendations! 1) Remove the original cluster and have the Tach repaired! 2) The dealer can replace the cluster with a new one but I believe from what I've been told needs to be sent out to have the correct milage programed into the Odometer!
Maybe Yes or Maybe No ,
halloffame
Sep 13, 2011 04:19 PM
Found uh HHR
Dec 2, 2009 06:54 AM
turbotim
Apr 21, 2008 11:33 PM
HillsdaleHHR
Jan 28, 2007 02:20 PM
