SS front bumper lower extension
Old 08-27-2014, 09:17 PM
skyline26's Avatar
Does anyone know how the extension attaches? is it push tab things or screws?
skyline26 is offline
Old 08-27-2014, 09:32 PM
Screws and push pins.
Your picture shows the screw locations. There are plastic trim pins on the ends.
firemangeorge is offline
Old 08-28-2014, 08:10 AM
skyline26's Avatar
thanks george...are they specific screws? are they only available from say the dealer or can any screw work?
Old 08-28-2014, 08:29 AM
LawDog88's Avatar
Probably a dealer item. Go tell them that some of them were lost during your last 'service' at the dealership as a result of someone having a brain fart. Tell them what you need, see what they say.
Worst case, you pay for them. Best case, you get them free.
Edit: I told my Chevy dealer that for my old Silverado, and they gave me like a dozen Plastic Push-Screws free. Good luck.
LawDog88 is offline
Old 08-28-2014, 09:23 AM
"can any screw work ?" Really skyline. You didn't actually say that,did you ?
Here's a picture of one of the screws. If I remember correctly, it screws into a metal screw/clip at each hole. You would need the matching clips for each hole. And,No, you can't swap it with a nut and bolt because you can't get a wrench on the top side where the clips are.
*that's a 7mm nut head on the screw.
I'm sure you could get these at any auto parts or even the hardware store.
Old 08-28-2014, 11:00 AM
skyline26's Avatar
called the dealer and they want $6 a screw! haha ya ooooook!
ill check out the parts stores around me as suggested..in case anyone is wondering the sizing is metric 4.2 x 1.41
Old 08-28-2014, 11:52 AM
That size screw is only going to work if you're using it with the corresponding same threaded clip.
Skyline. Since you don't have a SS, exactly what are you trying to piece together here ?
Old 08-28-2014, 11:53 AM
LawDog88's Avatar
SSLS or SSLT I'd say.
LawDog88 is offline
Old 08-28-2014, 02:08 PM
skyline26's Avatar
trying to piece together a front end..im sure the parts stores will have the clips as well
Old 08-29-2014, 06:14 AM
LawDog88's Avatar
Is it going on your HHR?
LawDog88 is offline
Quick Reply: SS front bumper lower extension
