Stumble
Old Apr 25, 2026 | 02:23 PM
BlueAngell's Avatar
Question Stumble
2006 HHR 2.2 5 speed about 96,000 she would run fine then shut off start back up wouldn't get out of its own way. Changed all injectors fixed that problem then a miss changed plugs fix that problem now has off idle stumble. once rpm's are up runs fine
Any ideas
TIA
Old Apr 25, 2026 | 04:13 PM
Welcome to the forum, any codes that support your replacement of the injectors , what spark plugs did you install. Have you cleaned the throttle body and MAF sensor? Is the MAF sensor plugged in firmly?
Old Apr 25, 2026 | 04:23 PM
This all happened in one day?
Old Apr 25, 2026 | 04:38 PM
Probably not , I’m thinking TB and MAF cleaning.
Kade082
Feb 12, 2026 11:21 PM
SullyinCT
Nov 3, 2023 07:14 AM
limachine
Jul 23, 2017 09:05 AM
lamindave
Dec 4, 2011 12:03 PM
Tyler Harvey
23
Aug 15, 2011 12:15 PM
