Rough Idle on Hot Start, clears up
Hey all, I'm original owner on a 2011 HHR 2.2L (non turbo) automatic. I've had 120K trouble free, hard driving miles. Lately I get a rough idle on a hot start, and it lasts 30 sec or so and clears up. No codes and no other symptoms. I popped a scanner on and saw #4 was showing up to 40 misfires so I swapped in a new coil there, but still have the problem. I can't find anything on a search. I was going to check fuel pressure, see if maybe #4 injector is leaking down, but its just a wild guess. What do you think?
Sounds good man. I'm gonna pop out the plugs to read them. I'm wondering if I've got a leaky valve guide, dripping a little oil into the cylinder on a hot soak. I tried to get away with the quick fix. I know alot of guys have complained about the valves, and I really put this little motor through its paces, so just a guess.
Misfires cause CEL (code), since they will kill a cat real fast. Those misfires are probably phantoms. Maybe your scanner thinks you have 6 or 8 cylinders.
Do you check your coolant level regularly?
Fuel pressure would be a good place to look.
Problem Solved!
It's been a while but I fixed my problem, and I found it kind of by accident. First off, the scanned misfires were phantoms, I realized a significant amount of misfires should trip the check engine light. Scanning another car with no symptoms showed a similar reading. So last week, my belt started making noise, and a few days ago it shredded. While changing the belt and tensioner, I noticed some dark oil on the frame rail, it was directly under the tensioner access hole, under the engine mount. The oil looks like WD-40 or PB Blaster. I dried it up and it came right back when I started it up. (I had no idea the HHR used a hydraulic mount, but there it was.) So a new mount took care of the leak which may have helped the belt to fail, and now the car is smooth as can be. So if you come across a rough idle, check for an oil leak at your engine mount. I flipped the old mount upside down for the picture.
tiggercross59
Sep 26, 2024 02:16 PM
to the forums!!
