Temp. Gauge and A/C
Old Jul 20, 2018 | 02:02 AM
Hopefully you nailed it with the sensor replacement. Did you actually actively clear the codes and reset the CEL after replacing the thermostat?
Old Jul 20, 2018 | 06:40 AM
tileman2692's Avatar
Yes I did, dexcool
no I didn't. How do I do that
Old Jul 20, 2018 | 06:49 AM
Either with a code reader with clearing capabilities, OR, you can disconnect the battery for 20 minutes to clear and reboot the car's computer system.
( disconnect the - negative terminal at the battery. Don't disconnect or touch the + positive terminal so as to avoid any shorting)
Old Jul 20, 2018 | 07:22 AM
And don’t close the rear hatch door!! It’s a bear to reopen manually!!
Put a folded towel over the latch to prevent it from closing.
Old Jul 20, 2018 | 08:22 AM
no I didn't.
Replacing the thermostat might well have fixed the original issue, but not clearing the codes would have left the error until it was cleared, or after a certain number of drive cycles.
blue car
Dec 2, 2019 06:08 PM
rad1steve
Sep 11, 2014 05:10 PM
Leemor
Jun 9, 2014 06:33 AM
Wifes07LT
Sep 3, 2013 08:44 PM
kornellred
Aug 26, 2007 06:39 AM
