Yeah I am beginning to wonder too - although he may have two HHRs.
No mention of check engine light - which should come on with a p0301 code. and he didn't anwer the question I raised about it. I'm out |
OK, in your 2006 2.4 HHR , it was designed for AC Delco Iridium 41-103 plugs
https://cimg3.ibsrv.net/gimg/www.che...62d2d08b20.png Those Bosch plugs can foul and cause a misfire code. |
Originally Posted by whopper
(Post 838047)
Yes, I remember he has 2 HHRs.
Agree, it could be the non-ACDelco spark plugs. That's an easy theory to test. |
(Post 838047)
Originally Posted by Oldblue
(Post 838048)
Originally Posted by donbrew
(Post 838033)
It is the p0301 that is setting the traction control and hard shifting.
After you do what Oldblue suggested you need to do a compression and leakdown test. |
Go to your "User CP" and set your notifications.
When you pull the plugs to do the compression test, double check them for differences between cylinders
(Post 838022)
Check this thread and it's suggestions - https://www.chevyhhr.net/forums/gene...d-shift-59930/
It sounds like a hub problem, but to determine which one you need to use a OBDII code reader that will read more than just the basic engine codes - some suggestions are in the above thread. |
