Traction control light; hard shift
Old Feb 8, 2018 | 01:32 PM
Yeah I am beginning to wonder too - although he may have two HHRs.
No mention of check engine light - which should come on with a p0301 code. and he didn't anwer the question I raised about it.
I'm out
Old Feb 8, 2018 | 01:41 PM
OK, in your 2006 2.4 HHR , it was designed for AC Delco Iridium 41-103 plugs
Those Bosch plugs can foul and cause a misfire code.
Old Feb 8, 2018 | 01:43 PM
Cat Man HHR's Avatar
I'm out
I'm going to follow you.
Old Feb 8, 2018 | 08:44 PM
Yes, I remember he has 2 HHRs.
Agree, it could be the non-ACDelco spark plugs. That's an easy theory to test.
Old Feb 8, 2018 | 10:00 PM
shojay92's Avatar
I'm out
yes I have two HHR's one is an 09 SS. The other is an 06 LT. Sorry for not responding. I didont get any notifications.
Old Feb 8, 2018 | 10:01 PM
shojay92's Avatar
Nah it was misfiring before I put the plugs in. Still does it
Old Feb 8, 2018 | 10:02 PM
shojay92's Avatar
Originally Posted by donbrew
It is the p0301 that is setting the traction control and hard shifting.
After you do what Oldblue suggested you need to do a compression and leakdown test.
Ok thanks for the info. I will check it out
Old Feb 9, 2018 | 07:10 AM
Go to your "User CP" and set your notifications.
Old Feb 9, 2018 | 07:37 AM
When you pull the plugs to do the compression test, double check them for differences between cylinders
Old Feb 9, 2018 | 01:55 PM
shojay92's Avatar
Check this thread and it's suggestions - https://www.chevyhhr.net/forums/gene...d-shift-59930/
It sounds like a hub problem, but to determine which one you need to use a OBDII code reader that will read more than just the basic engine codes - some suggestions are in the above thread.
Will so thank you:)
