Trailer wiring
Trailer wiring
My HHR has a receiver hitch installed, don't know if factory or not but where would the wiring/plug be and/or is there any trailer wiring kits for the HHRs? I am thinking to get a small trailer to haul my mower, but noting came up in the search?
Yes there were trailer harness kits available our sponsor CarID carries them
https://www.carid.com/curt/t-connector-mpn-55432.html
as does our friends at RockAuto
https://www.rockauto.com/en/catalog/...connector,2628
when I did my jeep, the plugs just connect inline with original plugs/sockets, you just route the wires behind the plastics use a drain plug or make a hole if needed to feed the wires through and done. I bought a bracket for the 4 plug outlet and mounted on the hitch for a clean install which should be the same for this. You never have to cut your factory harness which I like 100%.
