Transmissions…wondering
Old May 24, 2024 | 09:48 PM
Gearhead1's Avatar
I understand from what I read the the 4T45E was used in a few different models including HHR’s….my question is…can a different GM model transmission be put in an HHR and function correctly or is there different gear ratios and or programming?
Old May 25, 2024 | 05:27 AM
You can swap 4T45E transmission, there’s a compatibility list on line, yes there are different gear ratios
Old May 26, 2024 | 09:54 AM
PulpFriction's Avatar
What would you like different? The 4T45 is overkill for your car, even used in some GM 6-cylinder cars.
I've wondered if changing the ratio would freak out the ESC. Maybe someone here knows. Seems you can change manual transmission ratios without trouble.
Old May 26, 2024 | 10:01 AM
The 4T45E is the automatic transmission in every automatic HHR. The final drive ratios aren’t that different to confuse the TCM
Old May 26, 2024 | 04:28 PM
Gearhead1's Avatar
no change….just extra transmission possibly
Jimmy68
Drivetrain (Excluding Engine)
Aug 9, 2016 06:44 PM
LVJJJ
Dec 21, 2013 08:14 AM
PaperChaseHHR
2.2L Performance Tech
0
Oct 10, 2012 05:40 AM
HillsdaleHHR
Aug 25, 2008 09:33 AM
Lone Ranger
Aug 15, 2008 09:17 AM
