V8 HHR Build
Old Nov 8, 2016 | 08:52 AM
  #911
Very cool!
Old Nov 11, 2016 | 09:21 PM
  #912
lasater's Avatar
New View You Haven't Seen
I had the car on a roller bed today and I took this shot showing the rear undercarriage. If you expand the photo you can make out the cut outs and pretty much the entire drive train.
Old Nov 11, 2016 | 09:28 PM
  #913
WAY nice. And you even got a mug shot in there as well.
Old Nov 12, 2016 | 06:18 AM
  #914
Cool detail shot!
After 92 pages and 914 posts and over 2,000 visits Cliff has asked to make it a sticky, I concur!
Old Nov 22, 2016 | 10:15 PM
  #915
lasater's Avatar
New 9" Rear End
It's a long story, but I'm replacing the rear axle assembly on the V8 Panel. The Camaro axle is the Achilles Heel of the drive train. F body Camaros are notorious for differential failures, especially with over 500 hp. driving it. I also currently have 3.08 gears which are slightly tall for my needs. Since Currie Enterprises is just 8 miles from my work I've spent a bunch of time with them designing a new system.
I'm going with a custom width housing and custom 31spline axles of course drilled to 5x110 mm. The ford style 9" 3rd member will have 3.50 gears which will put me at 2100 rpm @ 65mph. Posi-traction and Wilwood calipers with drilled and slotted rotors finish it off.
With the line lock for massive burn outs, I kept having a reoccurring nightmare of having a catastrophic failure in the middle of frying the tires, thus the 9".
Old Nov 22, 2016 | 10:45 PM
  #916
Sweet.
I seem to recall a conversation about gear ratios for your build. Was a while ago but I was curious about that 3.08 choice back then.
Old Nov 22, 2016 | 11:02 PM
  #917
lasater's Avatar
Sweet.
The 3.08 was what the axle came with so it wasn't worth the money to change it. Since I can pick any ratio I want with the new rear end I'm gonna get what I want.
Old Nov 23, 2016 | 07:28 AM
  #918
Good choice!
Old Nov 26, 2016 | 11:56 AM
  #919
Fox Hat's Avatar
I love that you are taking your time and tweaking everything for awesomeness.
This machine is going to need a just as awesome name.
HHRendous comes out wrong
How about THHRemendous Tire THHRasher
Old Dec 4, 2016 | 01:05 PM
  #920
lasater's Avatar
9" rear end
Included in replacing the rear axle on the V8 Panel I must build all new brackets. Here are the cut pieces of the shock mounts and panhard bar mount It will take 6-8 more hours to complete them ready for welding onto the 3" axle tubes.
