IM Monitor Readiness?
Old 07-09-2018, 08:40 AM
romarpete's Avatar
I am getting ready for state inspection (NH) and my Actron CP9660 scan tool shows two IM readiness options.
1) Readiness since DTS codes last cleared (shows all IMs are ready)
2) Readiness for current drive cycle (shows half of IMs not ready).
I need to know which one of these options are necessary for the annual emissions inspection to be completed. I think it probably is #1 above but I would like to verify with someone familiar with the process.
Thanks in advance for your help.
romarpete is offline
Old 07-09-2018, 08:43 AM
I think you should be OK. If no codes are set.
Why were they cleared and when?
donbrew is offline
Old 07-09-2018, 08:49 AM
romarpete's Avatar
Thanks Donbrew:
The codes were cleared over a year ago after "misfire" was detected and fixed. I went through the tiresome drive cycle to reset everything at that time and haven't cleared any codes since. No DTS or check engine light since then. I just am not sure why my new scan tool displays the two IM readiness options. My old scan tool only had one.
Old 07-09-2018, 09:40 AM
X2 what Donbrew says, you should be fine.
Oldblue is offline
Old 07-09-2018, 09:57 AM
It is a totally irrelevant data point. Some of the tests run constantly some of them run once per drive cycle some run in the first 5 seconds some run under certain circumstances. Achieving a "drive cycle" without a computer is virtually impossible, but ordinary driving will accomplish the same thing in a week or so.
donbrew is offline
Old 07-19-2018, 02:36 PM
romarpete's Avatar
Thanks Donbrew and Oldblue. You were both right. I got my inspection sticker with no problem because the IM monitors were all "ready" since the last DTS were cleared. The "this drive cycle" IM monitor un-readiness was irrelevant.
Old 07-19-2018, 02:43 PM
great news ! Thanks for the update , so others won't have to worry
Oldblue is offline
Sandhog
11-17-2021 08:03 AM
diskullman
Tires & Wheels
21
06-19-2008 05:21 AM
Hotrodbob
10-02-2007 11:20 PM
Black Rose
02-05-2007 01:57 PM
DJNateGnau
12-23-2005 11:25 AM
Quick Reply: IM Monitor Readiness?
