GM Recall Campaigns For Information & Discussion of General Motors Recalls
Starts without a key.
Old Nov 7, 2023 | 05:24 AM
PulpFriction's Avatar
Good to hear the issue is resolved. Time will tell if it's permanent.
It's possible that the act of disconnecting the BCM, effectively resetting it, and not cleaning it, fixed the problem.
Bad electrical connections can cause transients that cause havoc with solid state electronics. The ignition switch might have had something to do with it. Twisting stranded wire together does not make for a good connection. I might suggest, instead of just taping, solder that white wire, or at least put a wire nut on it, and also explore what's under the red tape.
Old Nov 7, 2023 | 07:35 AM
Happy to see you fixed the questionable wires and cleaned the BCM connections, and the delve starting issues are resolved!
Keep it clean and drive it often!
Allen P
Jul 12, 2021 05:49 AM
howardt
May 25, 2013 10:50 AM
hhrlover101
Oct 21, 2012 10:34 AM
fsc44
Mar 7, 2012 04:02 PM
emstess
Apr 30, 2011 11:55 PM
