08 hhr ss prob
Old Apr 16, 2011 | 12:55 AM
skyrocket's Avatar
08 hhr ss prob
got an 08 ss and just bought the turbo pipes from dejon and worked great for a day then lost power had no boost, so i scaned it and had code P0101 Mass Air Flow. i was thinking i had loose connections at the tubes but all look good and are tight. has anybody had any of these problems?
Old Apr 16, 2011 | 01:08 AM
1Panel2NV's Avatar
Never heard of it.
https://www.chevyhhr.net/forums/ss-specific-service-issues-repairs-61/new-filter-throwing-codes-34795/
Old Apr 16, 2011 | 09:29 AM
gcsd3742's Avatar
These vehicles are very cantankerous.I get one from time to time I clear it with my Aeroforce.
Old Apr 16, 2011 | 09:48 AM
bartSS's Avatar
Is that the only mod you have???? The ic piping has nothing to do with your MAF
Old Apr 16, 2011 | 10:00 AM
1Panel2NV's Avatar
He could be talking about an intake too, which is what I assumed. He just said 'pipes'.
Old Apr 16, 2011 | 12:35 PM
skyrocket's Avatar
yeah i did the ic piping and the intake pipe also. so i took the intake pipe off and put the stock intake back on same problem.
Old Apr 16, 2011 | 02:47 PM
1Panel2NV's Avatar
The fuel trims need to be reset. I'm not sure how long it would take to adjust back to a normal value on it's own, but it should eventually. You could speed up the process by clearing the code and/or disconnecting the battery.
Old Apr 17, 2011 | 01:14 PM
skyrocket's Avatar
i've cleared the code twice now. never had a check engine light it stored as a history code it wasn't ever a current code. seems to be fine now.
Old Apr 18, 2011 | 07:15 AM
bartSS's Avatar
Yeah it takes 3 full cycles if you dont disconnect the battery. Return the intake get your money back and enjoy the stock intake my friend
Old Apr 23, 2011 | 12:23 AM
skyrocket's Avatar
yeah plan on returing it. thanks guys
87silver
Oct 18, 2011 04:22 PM
ssalamaca
May 1, 2010 06:19 PM
lowridergold
Feb 6, 2009 10:54 AM
TheBug
Jul 11, 2008 11:01 AM
Rcflyboy
Jun 27, 2008 10:18 PM
