08 SS brakes suck
Old Sep 17, 2008 | 09:29 PM
7m34life's Avatar
08 SS brakes suck
Every morning brakes suck, took to dealership and they reprogrammed brake controller on monday and its going back next monday for the same problem. Its my wifes car and she's always got my 2yr old boy and 4m old girl with her. Kinda ticks me off about it. Its scary when you back down our steep ass driveway and the pedal hits the floor.
Old Sep 17, 2008 | 09:46 PM
robotworkshop's Avatar
I expect that your HHR SS probably has the Automatic transmission. Although I haven't had this happen yet I have been watching all the posts carefully. It seems to be a known issue and GM is supposed to be working on an upgrade for our HHR SS with the Automatic. The problem has something to due with a lack of vacuum on the power assist. In the meantime if you let it run for a bit to build up vacuum it is supposed to be ok as a temporary work around.
To ensure that GM keeps focused on a fix you may also want to post (as several others have) on the following site:
http://www.nhtsa.com/
It seems that some of these are more prone to the issue than others but we'll probably all get an upgrade. Hopefully soon!!
Old Sep 17, 2008 | 10:01 PM
hyperv6's Avatar
The fix of a vaccume pump is coming and the goverment is not going to do anything since GM is already working on it. They already dropped the Sky and Solstice investigation since they were working on a fix..
GM does not want the liability any more than you want the hard pedal.
Old Sep 18, 2008 | 02:03 AM
08BlkSS's Avatar
is she letting it warm up before she just jumps in and drives off?? ..... this is one reason why I like the remote start so much. On cold starts I start it up a min or two before i go and the problem is fine...everytime i just jump in, start up and take off the brakes go to the floor. But everytime i let it warm up and the vac drops down to 20 all is good.....hopefully this will help
Old Sep 18, 2008 | 06:19 AM
WaGoN MOnger's Avatar
not to mention you should probly let the car warm up for or minute or too anyways. My car falls on its face unless i give it atleast a minute..
Old Sep 18, 2008 | 06:25 AM
a76marine's Avatar
What they said... while it's not the best designed brake system in the world, it can be overcome by letting the SS warm up before taking off down your steep driveway.
Old Sep 18, 2008 | 07:11 AM
Cokeybill's Avatar
Brake fix is the remote start...
Old Sep 18, 2008 | 08:31 AM
bartSS's Avatar
Do any of you guys that have this problem let your car warm up for at least 4 minutes in the morning.. I wait until the temperrature gets to 140 before i start driving and never had a problem
Old Sep 18, 2008 | 09:34 AM
Cokeybill's Avatar
I always use the remote start before I leave my suite. That way the brakes are never a problem by the time I get to the SS. All warmed up and ready 2 go.
Old Sep 18, 2008 | 10:00 AM
AaronSS's Avatar
Yet another reason I'm glad I got the 5MT.
