5 Speed guys I have a favor/ question for ya.
Old Feb 1, 2009 | 09:50 AM
BZERKED's Avatar
Now maybe I bumped my head, but I think the LSD will only lock up with output from the engine and not spinning the wheels on jack stands. If you have a LSD in a rear axle it's a given they spin the same way, but since this is FWD the wheels need some compliance in turning corners and only require the LSD in launching or high torque conditions. My old RWD LSD in use to lock and chirp around corners because the inner wheel was turning less than the outer. If both wheels were locked all the time in on FWD you would be fighting torque steer in every corner. I can tell mines locking when I wind it out because the torque steer wants to toss the whole rig into a ditch, like my RWD unit did. Not the case in typical driving conditions...
Old Feb 1, 2009 | 10:15 AM
BZERKED's Avatar
... forgot to ask, what drove the trans replacement??
Old Feb 1, 2009 | 11:42 AM
c2vette's Avatar
Originally Posted by BZERKED
Now maybe I bumped my head, but I think the LSD will only lock up with output from the engine and not spinning the wheels on jack stands. .
Maybe you missed my post, but I had mine up in the air, and when you rotate one wheel, the other goes the same direction. I think that was his original question.
Old Feb 1, 2009 | 06:17 PM
LT1GMC's Avatar
If you guys get some ice or snow down there, a quick check is to get one front tire on the ice, one on dry, then try to take off at a good pace(traction control off). That will tell you pretty quick if its got LSD. If you don't take traction control off, it will apply brakes on the spinning tire, forcing the other tire to help out, kinda an electronic LSD, but for low traction surfaces only, not drag racing.
Old Feb 2, 2009 | 08:06 PM
Unclesams_SS's Avatar
Comlpete failure. It craked in half.
Old Feb 2, 2009 | 08:12 PM
oneton's Avatar
Did you full power shift and get two gears at the same time ???
Old Feb 2, 2009 | 08:44 PM
BZERKED's Avatar
Holy #%&@! It blew apart!!! How many miles??
I did play with it in the snow today they both wheels do lock up like an old school Posi.
Old Feb 3, 2009 | 08:27 AM
In "Comp mode" no lift shifting from 2nd to 3rd @ wot.. The car was having some problems from day one and the dealer could not find a problem with it....so I guess I found the problem for them
Old Feb 3, 2009 | 09:00 AM
DrLoch's Avatar
Guess you did.
Old Feb 3, 2009 | 10:54 AM
prod's Avatar
Did they cover the new tranny under warranty? I thought there was a bulletin not to, as cracked tranny was considered abuse.
