adj. clutch?
Old Sep 25, 2008 | 04:30 PM
twistedamd's Avatar
adj. clutch?
i had my car in the dealer getting a clutch plate kit and sensor and ever since i got it back the clutch engages almost all the way out. i only have to push the pedal in about an inch to shift . also it does not go into 3rd gear in comp mode no matter how much i try. this was all good before dealership. the noise i went in for is still there and now i have this. can i adj the clutch myself on this car?
Old Sep 25, 2008 | 07:29 PM
twistedamd's Avatar
anyone?
Old Sep 25, 2008 | 09:49 PM
allsteelers's Avatar
The clutch is hydraulic and not adjustable. My recommendation is to take it back to the dealer to get it fixed correctly. Another dealer is not likely to correct the mistakes of the original dealer.
Old Sep 26, 2008 | 12:27 AM
jeffs396's Avatar
Probably air in the hydraulic line from the dealer's incompetence!
Old Sep 26, 2008 | 08:24 AM
o6designs's Avatar
Air won't cause it to act that way ( way out ). Air makes them spongy feeling and wonit release . Sounds like a pressure plate issue .And I agree with taking back to the dealer that messed it up giving them a chance to correct it.---o6 designs -Bob
Old Sep 26, 2008 | 01:12 PM
traketo's Avatar
Is the noise you hear when you first start the car while it has been parked for a couple of hours? I ask because when I start the car in the morning, it makes some weird noise. I have also notices the clutch has become very soft.
Old Sep 26, 2008 | 01:51 PM
twistedamd's Avatar
how does everyones clutch release? closer to the floor or all the way out? also on hills ill let the clutch out and the car will just sit there for awhile then it will go whats up with that?
Old Sep 28, 2008 | 08:52 AM
bartSS's Avatar
mine grabs about 3/4 of the way down
Old Sep 28, 2008 | 10:21 AM
mistermike's Avatar
Classic symptom of clutch needing a better bleed. Bleeding hydraulic clutches is time consuming and sometimes tricky. Two things that dealers like to avoid.
taz3
Maintenance and Upkeep
Nov 22, 2014 07:08 PM
B.Diggity
Drivetrain (Excluding Engine)
May 16, 2013 05:10 PM
B.Diggity
Apr 24, 2013 12:02 AM
Visionary Vectors
Oct 15, 2009 05:44 PM
