Any tips for a manual transmission n00b?
I stalled it on 2 hills this morning doh!! I'm fine going thru the gears and everything else but when I get stopped on a hill I'm like "oh ****". It didn't help that I was in a ton of traffic this morning with a car right on my ass on both hills. Is there any tips you guys can offer me? Is there some magical technique? LOL. I probably just need to practice.
Practice finding and holding the car at the friction point, but don't stay there too long or you'll start getting a burning smell. Do it on a flat surface until you get the hang of it. Then you can do it uphill.
Yves
Yves
That is a biggie there in itself. But from what I remember in my old drivers ed days when they actually taught you to drive a stick, use the emergency brake with the release button depressed. That way you can control roll back by raising/lowering the ebrake as you need. But practice will teach you on using the clutch the same.
I applaud you for giving it a go.
Gotta find where the clutch release keeps a grab on the gear and hold it as you watch the opposing light changes to yellow. Just touch a little gas during the process while your holding it there and then rocket out with 260hp!
If you get caught at a red light on a hill and because you have (I hope) only two feet you can also apply the emergency brake to hold yourself there and then as the light changes release the clutch and accelerate slightly against the applied brake before releasing it.
