Auto vs. Manual 1/4 mile and 0-60 times?
Old Feb 17, 2008 | 03:46 PM
Lone Ranger's Avatar
Are these published anywhere handy?... apples-to-apples as far as LSD goes, either each with an LSD or each without an LSD, but not one with LSd vs. one without LSD, that wouldn't be apples-to-apples.
Old Feb 17, 2008 | 03:54 PM
LT1GMC's Avatar
GM has published 0-60 specs for both cars, 6.3 sec for the stick, and 7.5 sec for the auto. LSD is only available on the stick car.
As far as apples to apples, comparing a stick to an auto which has 25 less hp, and one less gear, plus a much less advantagous overall 1st gear ratio, is not apples to apples.
Old Feb 17, 2008 | 04:09 PM
LT1GMC's Avatar
The auto car has a 3.29 differential ratio, which multiplied by the 2.96 1st gear gives a 9.73 ratio launch.
The stick car has a 4.05 differential ratio, which multiplied by the 3.38 1st gear gives a 13.69 ratio to launch off the line. Thats alot of extra torque multiplication.
2nd gear, auto 5.32 ratio(1.62x3.29), stick 7.12 ratio(1.76x4.05), advantage stick again.
Old Feb 17, 2008 | 07:12 PM
Old Lar's Avatar
0-60 would you get out of first gear?
Old Feb 17, 2008 | 07:49 PM
ralphb's Avatar
You forgot something - the multiplication of torque by the torque converter.
I have not seen data on the HHR SS auto application, but most automatic transmissions have a torque multiplication factor of somewhere around 2X the gear ratios.
Old Feb 17, 2008 | 09:04 PM
LT1GMC's Avatar
Only on the initial start, not thru the gear or in 2nd. That 2x is only up to the stall speed, (1800-2000rpm on a stock car) then rapidly diminishes or you would be slipping like crazy.
moonsign
Racing Discussion
61
Dec 24, 2012 08:13 PM
rgraboske
2.0L Performance Tech
16
Jun 2, 2011 08:27 PM
Dr_Jekyll
Racing Discussion
10
Aug 26, 2009 05:15 PM
da_dad66
2.2L Performance Tech
Apr 22, 2008 05:51 PM
doughboy
Apr 14, 2008 07:29 AM
