Automatic SS brake problems -- dealer results
2008 HHR SS Brake Problems
I own a 2008 HHR SS with serious brake issues. GM refuses to admit there is even a problem and sent me off to drive away in an unsafe vehicle. If you are one of the many people having brake problems with your 2008 HHR SS (auto) please contact
Green Welling LLP - National Class Action Attorneys
rsgclasscounsel.com
415-477-6700
They are evaluating the 2008 HHR SS brake issue. They have not yet decided to take the case, but they are gathering information. They need additional information so if you too are experiencing problems with your HHR SS brakes, please contact them and provide them with information. GM needs to fix the problem or work with us in finding a solution, not send us away driving unsafe vehicles. Not everyone is experiencing this problem. If you are not, disregard. If you are, help may be at hand.
rsgclasscounsel.com
415-477-6700
The "computer fix" is just a flash file sent to the transmission control module, so I am told, that in turn lowered the engine rpm at start up so the engine doesn't pull through the brakes guite as easily. The "Onstar"system doesn't see an anti-lock brake failure so why would GM? And yes they did that twice because the first time they did it they told me what they did but they didn't write it in their report! Perhaps you should try to price a vacuum pump, associated wiring and controls then ask why I don't just install it! Try contacting a pontiac or saturn dealer to get parts for a HHR! Or maybe find a salvage unit to rob the parts from! Ask someone with a Soltice or Sky if GM Fixed theirs!
As for class-action lawsuits, good luck. You won't see a dime for a decade. You're better off lemon-lawing the car if they can't fix the problem.
2. Next name the amount of money received by each member.
3. Advertising legal services without disclaimer is usually quite illegal in many jurisdictions and is a violation of terms of use of this forum without Supporting Vendor status.
Why would you expect the second time to do anything different than the first? Maybe it's the 7th time that does it. Maybe it's the 33rd. Or... since bits are bits, and there's a checksum at the end of the flash routine to ensure that those bits didn't magically change enroute to their destination, one flash of a particular firmware binary is sufficient.
I want to let you know that the "brake fix" is a flash of GM pulling head out of rectum only to reinsert and deny there is a problem! NO IT AIN'T FIXED and if the response was not GM's stand but that of a lonely engineer they should keep him off the phone! ... If I only knew his wife HA HA HA!!!
Has anyone else used the "LAUNCH" mode? The little rascal will take off in a straight line without the pull to one side fealt in the wheel . I think I'm gonna try it after it sets in parking lot at my dealers for a few hours and see how many cars I can hit! Maybe that will get their attention HA HA!!!
