Backfire
Old Jul 1, 2009 | 06:57 PM
JAXFL_SS's Avatar
Backfire
Ok. I searched and didn't really see much on this topic. My 08 SS has begun to occasionally backfire. Doesn't happen that often, but has happened about 3 or 4 times in the last week. It seems to do it in 1st or 2nd, say sitting in traffic. It did it yesterday...I was waiting at a light..pulled up about 20 yards in first (not hard on the gas)...pushed in the clutch..and backfire (like TA-DOW..not real loud, just noticeable). I guess that's what it is..more than the typical burbling I get. It doesn't really bother me, I just want to make sure it's not damaging.
Any ideas?
Old Jul 1, 2009 | 07:06 PM
MetallicaMatt's Avatar
has it been extra hot out or anything? might have pulled timing and running rich
Old Jul 1, 2009 | 08:19 PM
JAXFL_SS's Avatar
Yeah, definitely been hot. Upper 90's for last 3 weeks...
Old Jul 1, 2009 | 08:33 PM
hurm, not super crazy, i could understand if it was 100+, even then, I doubt it should be backfiring
has it thrown a code or CEL?
Old Jul 2, 2009 | 09:20 AM
JAXFL_SS's Avatar
Nope. haven't seen anything come up. Like I said, it doesn't happen too often and I can't seem to reproduce it on demand. I may take it by the dealer here in the next couple of weeks if it continues, but I suspect they won't be able to reproduce it either...
Old Jul 2, 2009 | 05:50 PM
MOTRV8D's Avatar
my z28 backfires when I get on it a little when it's cold. I know that's bad for the engine but I might have to do it to move out with traffic or get out of someone's way. Does yours do this soon after starting it up cold?
Old Jul 2, 2009 | 10:47 PM
JAXFL_SS's Avatar
naw. it usually does it after its been running awhile..more than 15-20 minutes usually.
Old Jul 2, 2009 | 11:39 PM
MOTRV8D's Avatar
try refueling to reset the computer.
grasping at straws here, but maybe the timing got screwed up if sitting in traffic for a while.
Old Jul 3, 2009 | 01:50 AM
JRACERX's Avatar
Could be as simple as a small exhaust leak, letting cool air in as you coast between shifts.
Old Jul 3, 2009 | 06:00 AM
pappa_smurf's Avatar
Talking I've had the popping noise myself.
Mostly I have noticed it after a long drive in the heat and if I take my time between gears with the clutch in. I drive a lot with the cruise on. Once I come off the freeway and get in stop and go traffic, that is when I will hear it now and then, but not too often. I still have less than 4,000 miles on the engine. But, like I said, it does it when the engine is warmed up on long drives.
