I purchased the Cloyes 9-4201SAWP kit that comes with the waterpump. Everything went together smoothly. I was triple checking everything as this was the first time installing a timing chain set.
I forgot to mention that I reused the balance shaft crank sprocket. That was the GM(55557168) the only gears I used from the kit were the intake and exhaust balance shaft gears.
That’s good information, you reused the OEM sprocket, ok .
can you possibly get a photograph or video of the balancer spinning, to show it’s out ?
Just a thought, are you sure the balancer engaged the oil pump? The flat spots on the oil pump impeller lined up with the flats Jon the balancer?
just checking, it has been mentioned before.
