Bent crankshaft
Old May 7, 2021 | 10:36 AM
Which crankshaft gear and balancer did you use? Part numbers please.
Old May 7, 2021 | 12:55 PM
Namnevele's Avatar
The balancer was a Dorman 594-309 and the crankshaft sprocket was a Duralast S-849 which had the GM number on it (24424758)
Old May 7, 2021 | 02:06 PM
The crankshaft sprocket for the timing chain is part number 24424758
It fits the 2.0, 2.2 and 2.4 litre engines
the balance shaft crankshaft chain sprocket is the different one, only fits the 2.0 LNF
Old May 7, 2021 | 04:21 PM
Namnevele's Avatar
I purchased the Cloyes 9-4201SAWP kit that comes with the waterpump. Everything went together smoothly. I was triple checking everything as this was the first time installing a timing chain set.
Old May 7, 2021 | 05:26 PM
According to what I see at GM, neither sprocket is specific to the 2.0.
Old May 7, 2021 | 05:45 PM
The balance shaft chain crankshaft sprocket in that kit does not fit the 2.0 LNF
in the Cloyes video he mentions that. Please watch it again
Old May 7, 2021 | 06:27 PM
Namnevele's Avatar
I forgot to mention that I reused the balance shaft crank sprocket. That was the GM(55557168) the only gears I used from the kit were the intake and exhaust balance shaft gears.
Old May 7, 2021 | 06:39 PM
That’s good information, you reused the OEM sprocket, ok .
can you possibly get a photograph or video of the balancer spinning, to show it’s out ?
Just a thought, are you sure the balancer engaged the oil pump? The flat spots on the oil pump impeller lined up with the flats Jon the balancer?
just checking, it has been mentioned before.
Old May 7, 2021 | 06:50 PM
Namnevele's Avatar
I do have a video but it said the file was not supported. Yes I made certain that the flats on oil pump and balancer aligned.
File Type: mov
Old May 7, 2021 | 06:56 PM
Try here
