Boosting issues
Old Oct 26, 2019 | 03:41 PM
Justin3315's Avatar
Not a bad idea
Old Nov 16, 2019 | 10:31 PM
Justin3315's Avatar
Upon closer inspection my lower plug and play showed signs of damage inside the connector,that's resolved now, andi just picked up a bluetooth obd2 reader for monitoring on the fly and I'm getting consistent codes while experiencing the issue or not and only once earlier I got a different code
Old Nov 16, 2019 | 10:54 PM
Is the second one after the codes were cleared?
Old Nov 16, 2019 | 11:03 PM
Justin3315's Avatar
The p0101 was just a random one earlier today I've been clearing them all day trying to see which are more persistent and I only seen the MAF related one once
Old Nov 17, 2019 | 04:11 AM
Justin3315
Could you explain what sort of damage you had inside the wiring connector ? I have the plug-n-play connectors on mine and would be interested to know how your's became damaged.
Old Nov 17, 2019 | 08:37 AM
  #26
They are all MAF related. Thae baro comes from the TMAP the air temp comes from the MAF and the TMAP,
I asked the question because your OBD2 reader has a "different" way of displaying results than I am used to. If the second one was done after clearing then none of the first ones matter, they are history.
You still have a wire problem.
Old Nov 17, 2019 | 11:01 AM
  #27
Justin3315's Avatar
Fireman the connector looked like it had been hit and bent on the sensor side several times the purple wire doesnt feel like there's much wire intact inside
Old Nov 18, 2019 | 05:27 AM
  #28
Thanks for the info.
Old Nov 18, 2019 | 04:44 PM
  #29
Justin3315's Avatar
Anyone got any suggestions on which area to look next
Old Nov 18, 2019 | 05:02 PM
  #30
Did you repair the purple wire?
