The Brake Fix Is In
Old Jan 27, 2009 | 06:53 PM
ChevyMgr's Avatar
The programming will not work with a manual. For the SSs that have had the upgrade done, after the pump is installed the tech will have to reprogram and select the option "with vacuum pump".
Old Jan 28, 2009 | 12:23 AM
Cokeybill's Avatar
Originally Posted by HPVOHHR
From observation of info in various threads...
... posts about the Stage Kit seem to indicate that there is a specific engine calibration associated with vehicles that have the vacuum pump... and the special "pump" calibration is AT specific.
So, retrofitting the pump hardware to a 5-spd vehicle likely wouldn't just be a case of installing hardware and splicing into harnesses etc... some support would be needed from the software side as well.
Just a note... I have never experienced any issues with my 5-spd. I live in Ontario so the vehicle has definitely seen a huge range of cold-hot temperatures.
I did a couple of times good buddy, but I use the remote start and by the time I get to the SS, it's already idled down and ready to go.
Get that Kit installed ==> sell the house, family or anthing.
Old Jan 28, 2009 | 11:52 AM
jerSSey HHR's Avatar
So if I bring my SS in to the dealer, they will know how to fix and have the parts to do it? Can I expect it to be done in one trip, or do I need to bring it in one day, then have them order stuff, and then bring it back another day?
Old Jan 28, 2009 | 12:02 PM
ChevyMgr's Avatar
No. But you can give them the bulletin number. #09-05-22-001
No.
Yes.
Old Jan 28, 2009 | 12:06 PM
ugh
Old Jan 28, 2009 | 12:33 PM
hyperv6's Avatar
ugh
Wait till the weather is better so it will not be a wasted day.
Old Feb 7, 2009 | 01:09 AM
CGYHHRSS's Avatar
Thanks to ChevyMgr from bringing this to attention on here.
Talked with the dealer, passed on the TSB, and they've ordered the parts and should be here within a week to do the fix.
They've flashed the ECM 2 times in past 10 months and still having the issue.
Old Feb 9, 2009 | 07:58 AM
REDHHRSS's Avatar
Well I now have the vacuum pump installed. Dealer was given 3hrs to do the install and it took them 7hrs. They weren't to happy about that. It seems to have fixed the problem. Seems funny that boost gauge still reads low vacuum on startup like it did before but I have brakes. I guess that's all I wanted.
Pat
Old Feb 9, 2009 | 09:48 AM
robotworkshop's Avatar
Can you post some pictures of the upgrade? Where does it mount and what does it look like?
Old Feb 9, 2009 | 12:39 PM
REDHHRSS's Avatar
I looked but I can't see it. It's buried under a bunch off hoses and stuff.
