Brakes for the HHR/SS are the same as:
Old Apr 15, 2010 | 12:32 PM
Gone Blue's Avatar
great, thank you solman and bad03! G.B.
Old Apr 17, 2010 | 07:44 AM
87silver's Avatar
Originally Posted by bad03xtreme
That is only meant for those with the "Brembo brake option".
The Brembo Calipers are larger than the standard calipers, thus needing the larger diameter wheel.
I was unaware that the Brembo option was available in 2008. If the single pot calipers and associated rotors in 2008 are the same side as those on other HHR models, why would the '08 (not '09) Owner's Manual state the following?
Perhaps it is in the '08 manual anticipating the release of the Brembo option for '09? Has anyone tried putting the donut on the front of a stock '08 SS?
I say this because if the time ever comes, I don't want to jockey tires unnecessarily.
2008 HHR Owner's Manual:
The SS Model has larger performance brakes than
the Base Model. The compact spare tire will not clear
the front brakes.
Do not use the compact spare tire in the event of a front
flat tire.
You must use the rear tire to replace the front flat tire.
Old Apr 17, 2010 | 05:01 PM
crazysteve's Avatar
The front non Brembo brake on the SS do differ from the regular HHR brakes 15's will not clear them
Oldblue
Nov 24, 2013 11:18 AM
ImNewHere
Maintenance and Upkeep
20
Aug 4, 2012 02:12 PM
agrandad
Feb 7, 2012 11:13 PM
mrarff
0
Jan 7, 2011 08:15 AM
