Brembo Speed Bleeders
Old Jan 25, 2021 | 08:14 AM
Rocky1974's Avatar
Does anyone know the Part# for the Russell Speed Bleeders that fit the Brembo Calipers? I'm ordering something from Summit Racing and need to spend another $20 to get free shipping, so I thought a set of Speed Bleeders would do the trick, but Russell doesn't even list HHR in their catalog. I know that they make them, because converted my last HHR SS to Brembos and used them, and I wrote down every single part# that I used, except of course, the Speed Bleeders.
Old Jan 25, 2021 | 08:40 AM
I think you’ll have to measure the threads and length I see 10 mm diameter threads with 30 mm or 33 mm length
the Russel site does not show HHR , but they do have a listing for Cobalt but not specifically the SS with Brembo brakes.
that begs the question are your rear brakes the same sized bleeder screws?
Old Jan 25, 2021 | 08:46 AM
You could send a PM to blue SS. He might know. https://www.chevyhhr.net/forums/main...e-lines-35442/
Old Jan 25, 2021 | 09:08 AM
Rocky1974's Avatar
Ha! I see you ran into the same shortcomings in the Russell Catalog that I did. I also own a 2010 Camaro with Brembos and Russell's catalog lists the same bleeder for it as a 2009 Colbalt, but like the Colbalt, Russell doesn't differentiate between the Brembo and non-Brembo equipped models. Maybe that means they're the same, but maybe not. I can't think of any practical way to measure my bleeders without removing them. The whole point is not taking my car apart until I get the parts to put it back together. I'm going to call them as soon as they open. Thanks
Old Jan 25, 2021 | 09:52 AM
I think the Camaro Brembo bleeders will be different for the SS then the stock Camaro SS non Brembo
Old Jan 25, 2021 | 07:13 PM
Rocky1974's Avatar
I agree, but the Russell Performance Catalog doesn't differentiate between Brembo and non-Brembo bleeders for the Camaro, just like it doesn't for Cobalts. I do believe that the Camaro Brembo bleeders are probably the same as the Cobalt Brembo bleeders. I did some research this evening and came up with this info. The GM part# for the HHR Brembo bleeder is: 25900782. It's dimensions are: 10mm x 1 x 31mm. The closest Russell Performance Speed Bleeder is part# 639630. It's dimensions are 10mm x 1 x 33mm. There's another Russell Performance Speed Bleeder part#: 639560. It's dimensions are 10mm x 1 x 35mm. I believe this 2nd number is the one I used last time. But this time I ordered both, just to be safe. I'll update this, if and when I learn anything new. Thanks for the help.
slimsol
May 1, 2010 09:41 AM
VictorySpark08
Mid Central
12
Jun 19, 2009 10:31 PM
edawg
Aug 24, 2008 02:08 PM
en0oNmAI
2.2L Performance Tech
18
May 3, 2008 02:40 PM
JOEK86
Oct 3, 2006 04:43 AM
