Check Engine Light 2010 HHR SS
Old Jul 11, 2019 | 08:53 PM
From our great friend Whopper a how to
https://www.chevyhhr.net/forums/how-...13-14-a-28779/
that valve , see post#3. In here
https://www.chevyhhr.net/forums/prob...roblems-59825/
Old Jul 11, 2019 | 09:40 PM
The CEL will go out after a bit. They will clear with a lobotomy. On an SS the EVAP purge valve may be slightly different location.
Old Jul 11, 2019 | 10:16 PM
RBodeman's Avatar
A huge thanks to both of you. I will try these repairs hopefully this weekend.
Do you think it's good practice to disconnect the negative from the battery before doing any of these repair since there is wiring involved and I don't wanna f-up anything if something touches the wrong thing will manipulating stuff.
Old Jul 12, 2019 | 09:35 AM
Yes , always disconnect the negative cable , when changing sensors , switches and other electrical things to avoid a possible short and reset the computers.
Old Jul 12, 2019 | 01:13 PM
RBodeman's Avatar
HELP - Where is my EVAP Purge Valve
Where is the EVAP purge valve on the SS?
I'm running code P0496 and want to change this part but for the life of me, I cant find it.
Old Jul 12, 2019 | 01:26 PM
Old Jul 12, 2019 | 01:28 PM
RBodeman's Avatar
Seriously?? Its right there under my nose?
Old Jul 12, 2019 | 01:50 PM
And oddly enough, looks exactly like the new one in your hand!
Old Jul 12, 2019 | 04:40 PM
Threads merged...
Old Jul 17, 2019 | 12:55 PM
RBodeman's Avatar
Smile
UPDATE. Check engine light is out. I did the suggested repairs of changing the EVAP purge solenoid, I did both the intake and exhaust VVT Solenoids and the gas cap.
She started up beautiful and is smooth a silk again with no lights. Thanks tons to you guys. Parts cost me just under $200 and took me about 4 hours. The vast majority of the time was spent on that Air Filter Box. All thee rubber grommets broke when I got it off as well. They are called insulators as per GM Parts. But I made my own rings with duct tape for the front two as a short term fix until I order them
