Check Engine Light 2010 HHR SS
Old Jul 18, 2019 | 10:05 AM
  #31
Originally Posted by Lethal Tendencies
Just got the code PO496 myself. Ordered the purge solenoid back by the canister filter. If that doesn't work has anyone tried a smoke test on the evap system to check for leaks?
I guess you missed the first couple of pages. P0496 means there is purge flow when not commanded; the purge valve is stuck open (under the hood).
Old Jul 19, 2019 | 10:51 AM
  #32
Lethal Tendencies's Avatar
oh. first i got check gas cap message with a CEL PO445. Replaced gas cap reset computer and now I get a CEL with po496.
Thanks for the help
Old Oct 3, 2023 | 06:39 PM
  #33
tinkamon@yahoo.com's Avatar
Check engine light came on while driving. Stays lit continually. Car's performance is good. No problems starting, running, or any other time. 1/2 tank reg gas.
Old Oct 3, 2023 | 08:14 PM
  #34
You have a HHR SS ? If so, you need to pull the codes and post them here. Not descriptions- code #’s only if you want us to help.
If this is not a SS, you should post in another forum section.
RBodeman
Nov 7, 2022 06:37 PM
ErinLeigh
Jun 22, 2017 05:21 AM
Highwang
Nov 28, 2013 07:45 PM
Madmatt6988
Apr 28, 2013 01:42 PM
chefhhr
Dec 19, 2012 09:12 AM
