Decent replacement turbo setup?
Old Mar 29, 2023 | 08:36 PM
hhrumadbruh's Avatar
What's decent that isn't $700+ for OEM? or can I rebuild the oem turbo?
Old Mar 29, 2023 | 10:28 PM
greg8453's Avatar
Decent costs money. You can save and buy junk.
Old Mar 29, 2023 | 11:46 PM
https://zzperformance.com/products/k04-turbo
sold out, sign up to get notified.
https://www.ebay.com/itm/313964306725
Google is your friend
Old Mar 30, 2023 | 06:21 AM
How long will the eBay turbo last?
Old Mar 30, 2023 | 07:04 AM
It’s new, so it’s gonna have same lifespan as ZZP turbo.
Keep your oil changed and clean. Let it cool down at idle after a drive and it should last a while.
Are you sure the rings aren’t the problem?
Old Mar 30, 2023 | 07:14 AM
Putting a new turbo on a worn out engine usually does not have good results.
Old Mar 30, 2023 | 07:55 AM
PulpFriction's Avatar
Lots of stories of cheaper aftermarket matching factory specs failing quickly. Member here has rebuilt OEM with success. Maybe m_ridzon?
Quite a few owners use the opportunity to upgrade to a larger quality unit, but that is not a low-budget approach. Much of what I've read was on an HHR SS group on you-know-where. Have you scoured the threads here?
Old Mar 30, 2023 | 08:38 AM
I can't say for sure. Each cylinder was at 130psi.
You guys probably remember the sludge inside the valve cover and all over the camshafts. Im guessing the oil lines to the turbo got blocked up? It only seems to spew smoke after boost pulls. Freeway driving seems fine as I'm guessing its cooling the turbo more than city driving.
what defines a warn out engine?
I would love to rebuuld the existing turbo if that's possible. I guess I just have to take it apart and see. But I need the second car as a backup to get to work....
Old Mar 30, 2023 | 08:58 AM
More Lipstick.
Old Mar 30, 2023 | 09:23 AM
Before you attempt anything, read this thread:
https://www.chevyhhr.net/forums/hhr-...rebuild-61246/
